How to move points/curves/faces in normal direction?
Hi @Trav,
I like your SubD-ring-tutorials very much: Rhino - Learn to use Rhino
Do you know how to move SubD points/curves/faces in normal direction? I thought MoveUVN should do it for points, but it seams not.
SubD-Herzring.3dm (374.4 KB)
Thanks
Michael
www.flexiCAD.com
Hi @Michael_Meyer
Use F10 to turn on the control points/cage for the subd, select those and then use MoveUVN - that should work :grinning:
HTH, Jakob
Jakob beat me to it.
If the selection is fairly simplistic to average a normal you can also set the Gumball to Align to Object and tug in the normal direction.
Hi @Normand and @Trav,
thank you very much.
_EditPtOn and _PointsOn work fine with _MoveUVN, but not vertices.
Is this a bug/oversight?
Thanks
Michael
