Diagrid facade - polyline warning
Hi
I’m getting this warning “zero length segments were collapsed to create a valid polyline”
can someone help me fix this warning…
facade_panelling4.3dm (655.1 KB) diagrid.gh (13.8 KB)
There are two corner triangular panels that have duplicated points among their 4 points of vertices.
You can ignore the warning or If you really don’t like it, then, you can cull them.
diagrid_ re.gh (15.1 KB)
The reason error message shows up because your list has multiple points with same coordinates, so outputting zero length lines.
Can be easily solved by this:
P.S: Same time upload ha-ha.
Cheers,
BVR
Hi Thank you for the reply.
I would like to add a point attractor to the definition for controlling the opening size.
Is it best to use the attract component? and should I connect to the scale?
Thank you very much for the reply.
diagrid_ reV2.gh (17.5 KB)
