I wanted to test if I can work using Detail Views as Modeling Views, but it looks like there is a bug and Layer visibility icon do not update in the Layers Panel correctly. So, apparently it’s not possible right now.
Hi @Czaja,
Sorry I missed this. From what I can see, the tool is working correctly.
Do you have any questions I can answer?
Thanks,
– Dale
Not really.
Start of the video:
Both Page 1 and Page 2 have the same Detail Visibilty (ON) yet in the Detail View on Page 1 the red Brep is hidden.
00:08
Being on Page 2 I turn Detail Visibility from ON to OFF and it incorrectly turns off also on Page 1.
00:12
Being at Page 1 I turn Detail Visibility from OFF to ON and it also changed the Detail Visibility on Page 2 - it should be OFF but it’s now ON. However, you can see that layer geometry is still invisible - Check the video at 00:20
These are Detail Views and both of them are activated on different pages, this might be something interfering with the correct icons in the Layers Panel. I know the video might be confusing, but I had no better way to show it.
Hi @Czaja,
OK, I see the redraw issue (tough tracking the video). I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-83357
To refresh the panel, click on a layer (so the control has focus) and press F5.
Thanks for reporting.
– Dale
RH-83357 is fixed in Rhino 8 Service Release 11
It is not fixed. It is still present in Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01001
Aha this might be something else, i thought this was the issue.
My problem is that when working inside layouts, geometry in the detail views disappear spontaneously and then appears again when double clicking inside detail and exiting the detail.
Hello @dale, earlier today i sent my full model to support in reference to other issue (BUG same section style different hatch on solids)
you can investigate the very same model for the behaviour i am reporting here. try to work in whatever layout i have in the file try to add dimensions etc, you will notice how geometry is disappearing in the detail views and refreshing once you double click into details and escape them. it is super annoying and should be fixed because the work is unsustainable this way!
I am seeing this intermittently in your file.
