I have experienced an issue multiple times with a file I’m working on where many Detail Specific layer visibility settings will inexplicably change for some but not all of the details in my document. This is not related to Global visibility changing, I have only been using the detail visibility lightbulb. I then have to go through each detail and change the visibility settings back to what they were to fix this. I also had no Layer States saved in the document so I can’t see that as the cause.
Is there something I’m missing that could cause many details to suddenly have different visibility settings? This is a major headache across my 40 page document.
Which version of Rhino are you running? Run SystemInfo and post the results.
We don’t have other reports of detail layer visibility changing on its own, so I suspect something in the workflow is triggering it.
One thing to check: in the Layers panel, right-clicking a layer’s detail visibility lightbulb gives you Layer Off in this Detail Only and Layer On in this Detail Only, each with a This Layout and an All Layouts option. On a layout page with details selected, the menu has the same pair as Layer Off/On in Selected Detail Only.
The “only” in those names means they affect every other detail too, not just the chosen one:
On in this Detail Only turns the layer off in all other details.
Off in this Detail Only turns the layer back on in all other details, including any where you had already turned it off.
With All Layouts, that applies to every detail on every layout. In a 40-page document, the result can look like visibility changed in some details but not others.
If that isn’t it, a few more questions:
Do you copy and paste details or layouts, and use Undo around those steps?
Do you use linked blocks or worksessions?
Do you run any scripts, Grasshopper definitions or plug-ins that change layer visibility?
If you can share the file, ideally right after it happens, that would help. You can upload it here: https://www.rhino3d.com/upload
I wasn’t aware till now of the right click menu for the Layer visibility toggle, so I haven’t been toggling using these options, only the lightbulb. I’m assuming the only way to access the All Layouts option is through the right click menu? I don’t think I’ve triggered this accidentally for multiple layers at a time, but I do see how this would be the most likely cause so I will try and investigate.
I have been both duplicating layouts and copying details throughout the document.
There are no linked blocks or worksessions
I’m not running any scripts.
I’ll share the files on your upload link before and after the issue.
While working on these layouts more this behavior occurred again to details from recently drawn pages, so I want to confirm that this is some sort of bug.
The highest potential cause seems to be duplicating other layouts in the document. Wondering if there are multiple instances of a detail referencing the same visibility settings behind the scenes?
To answer your questions: yes, the This Layout and All Layouts options are only on the right-click menu. And duplicated layouts and copied details each get their own copy of the per-detail layer visibility settings. They don’t share them with the original.
To help, we need a way to reproduce what you’re seeing. So far I don’t have a series of steps that makes per-detail visibility change on its own.
When you upload your before and after files, include as much as you can about what you did between the two saves:
Which layouts you duplicated, and which details you copied or pasted.
Whether you used Undo, and after what.
Any layer changes you made: turning layers on or off globally, adding, deleting, renaming or moving layers, and which details you made active while doing so.
Which details changed, and which layers in them changed.
If you can, save the file under a new name before each step. Then, when it happens again, we can narrow it down to the one operation that caused it.
I haven’t been able to reproduce the issue via a series of steps yet, I’ve been keeping close attention whenever I duplicate layouts, change layer state visibility, or adjust clipping sections to see if any of these actions trigger the change.
I was able to carefully restore all of the correct settings to my details using layer states. Thanks for your attention to this and I will update the thread if I have anything new to offer.
