Hey, huge fan of per-detail layer visibility here. I use it every time I create drawings.
Problem is, the function sometimes acts up totally messes up all the visibility settings in every detail. When it happens, every layer’s per-detail visibility in every detail is turned on, for all the layers with global visibility on.
It’s not on undo stack and it’s not reversible. Meaning that if it happens, I have to either go into each detail and turn off all the irrelevant layers, or I just roll back to the previously saved version.
I don’t have a video of this happening, but after having this happen to me more than several times, I have a hunch that it is more likely to happen (a) when I copy/paste details and undo that copy/paste operation (b) when saving and restoring layer state. It also tends to happen more often when the 3dm file is large and complicated with many layers and details.
Does anyone have the same thing happen to them, know why this happens, or how to prevent this?
Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3050 6GB Laptop GPU (NVidia) Memory: 6GB, Driver date: 10-9-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.57
Integrated accelerated graphics device with 4 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2025 for R8\RhinoArt1FileExporter For Rhino8.0.rhp “RhinoArt1FileExporter”
C:\Users\WonjoonOh\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\BlockEditNew\2.1.4\blockeditnew.rhp “BlockEditNew” 2.0.0.0
