Hi all,
I’m using Dendro’s vOffset and I’m getting unexpected (inaccurate) results. I have the Voxel size set to 0.015mm and an offset of 0.325mm. But when I measure it is only offset by 0.22mm.
Any thoughts?
Hi all,
Any thoughts?
Make sure the Bandwidth value going into Dendro vSettings is larger than your offset amount. Try making the bandwidth value 2.00 and see if that fixes it.
Other issues might arise if you are using multiple overlapping vSettings components. There should only be a single vSettings component serving any given set of volume generation and mesh outputs.
