Deleting materials
I have started testing the different display modes - especially raytraced/cycles - on my Mac(s). Raytraced is a great addition to V6.
However… It doesn’t seem to be possible to delete materials from a file (at the moment )…? I have a file where I’ve been testing almost every material that ships with V6 WIP. Now I’d like to get rid of those that I don’t want. How?
Philip
Hi Philip - in the Material panel you can delete materials directly. You can filter the view for use or unused materials in the context menu there.
Hi Pascal
This is what I get when I right click a material (right clicking is what you meant to get those pop ups, right?). That was the first thing I tried - no luck as you can see.
Thanks!
Philip
Hi Philip
if I understood correctly…
Then if you add the material tab [from that right click menu in your screen shot]
then left click the material tab and then left click the pizza stack icon [next to the help icon]
Akash
Aah, yes, thank you! Right in the beginning I removed the materials icon from the top row when I saw the materials icon in the second row (when you have the object properties icon in the top row active and are selecting an object in a viewport). Even if I know that it’s file properties versus object properties, it’s still a bit confusing having the same icon In two places almost side by side - especially when they behave differently. The top row has the right click option (as in Pascals screen shot) - but no right click option in the second row (is it just missing right now?).
Philip
Hi Philip - my right clicks are in the ‘dedicated’ materials panel… separate from the object properties material section…
The context menu for the (new content control), the control showing the material in the object properties page is not yet implemented. I have it in my list to implement. So there will be also a similar drop down menu like the one in Windows has.
Yes, I figured that out now - with a little help :grinning:
Thanks!
Philip
