I’m working with the RhinoInside.Revit API. I’m looking to create a Python equivalent to the New Component Family node. Or, in summary, trying to find a way to create new families in Revit via Python.
To do this, I understand you need:
- a Template file
- boolean option to overwrite family if existing
- boolean option to overwirte parameters
- string family name
- Revit Category
- Revit Geometry
When you opt to do this in Grasshopper you don’t need to provide a template file. Does the grasshopper node look at the Category you are using then go to the Revit version>Family Templates and grab the ‘best match’ default template? Or what is happening behind the scenes here that makes it so that you don’t need to supply a Template input? I’m suspicious of my assumption because I’m able to make Structural Connection families in Grasshopper, but I don’t see a corresponding Structural Connections.rft template in the Family Template folder.
Also, when it comes to passing Geometry to Revit should I be using this website/method as API reference? I see it’s for 2022, but still seems like the most comprehensive RiR API documentation I can find.
GeometryEncoder.ToSolid Method (Brep)
Thanks,
Dan
