When you use a new family component, the Rhino geometry will be created inside the family as a Directshape. “Baking” is Revit is pretty much the same as creating the element.
Once the family is created, you can edit the family using Revit native tools and add constraints and controls.
Am I correct that in order to transition the geometry created in Rhino to Revit, a Directshape component is required in the grasshopper definition?
Where does one add the component to the definition? I have been working off of the guide provided here https://www.rhino3d.com/inside/revit/beta/guides/revit-types
“Creating New Families.” I can get the object created in Rhino to appear, but cannot bake the selected object into Revit.
