Decals in Rhino 6
Hi All
Question: Is it possible to “clip” a decal in 3D in order to limit it’s influence on the object in other ways than “forward” / "backward?
I wish to add a decal with the “ekko”-logo on the INSIDE of the room WITHOUT applying to the outside of the opposite (U-Shaped) wall. Similar with the larger logo on the wider wall with the larger logo.
I solved the latter by detaching the opposing wall and thereby avoiding the U-Shape. The sliding doors have two different decals on either side. It is OK just to attach two decals (one on either side) on both doors, but it would be much nice to have a “Decal Symmetry=On/Off” toggle :slight_smile:
Check the “Named Views”, “Named Positions” + “Snapshots” for easy reviewing different scenarios.
Kind regards Tim Elkær, Erazmataz@gmail.com
P.S.
None of the decals (added in Rhino 6.0 SR31) are translated when
using the newest version (Dec. 2020) of KeyShot 10’s “LiveLinking”.
Command: _SplitFace
Select a face to split
Select a face to split. Press Enter when done
Start of split axis ( Curves ): Curves
Select split curve
Select split curve. Press Enter when done
Creating meshes… Press Esc to cancel
1 surface added to selection.
Command: _ExtractSrf
Select surfaces to extract ( OutputLayer=Input Copy=No ): OutputLayer=Current
Select surfaces to extract ( OutputLayer=Current Copy=No )
Select surfaces to extract. Press Enter when done ( OutputLayer=Current Copy=No )
Extracted 4 surfaces from a polysurface.
Command: _Cap
Created 2 caps, resulting in one closed polysurface.
Command: _Join
Surface join in progress… Press Esc to cancel
4 surfaces or polysurfaces joined into one open polysurface.
Command: _Cap
Decals+NamedPositions.3dm (578.0 KB) Logo_EkkoFilm_220x80_ba_$3dm$Embedded$_AA0BE7FB
moved to Rhino for Windows category
Hello - no, it ‘transmits’ through the full object - it would be nice to have sub-object decals but we don’t.
This is how Decals=Labels are implemented in KeyShot 10. The “Depth” is limitting the influence of the decals. Unfortunately you need to reapply decals manually, since they are not exported/imported correct.
GUI_KeyShot_10_Label-Decal_Limited_Depth
Guys - Hi and thanks for allowing me in .
I’m trying unsuccessfully to find a step-by-step process for allying simple decals to surfaces - "Step-1 “where to find the command” 2. … 3. … etc.
ANY suggestions as to where I could find this " All I can find wherever I look is "You can do this and this … " with NO how-to . I’ll re-post this , but all I’ve found anywhere is this OLD thread .
Thanks for ANYTHING you can offer , and my sincere apologies for reviving this WAY OLD thread !
  • C .
In Rhino 6/7/8 a Decal is a “property” of the selected object (Surface or PolySurface). Therefore you should look for the green rectangular icon called “Decals” in the Properties-Panel (Rainbow-colored-wheel) after selecting the object, you would like to stick the decal onto. Then select a Bitmap from Finder (Mac OS) or Explorer (Windows).
