Decal projection problem in Brazil
I would like to project the decal only in one side of the glass.
The decal also appears on the other side of the glass althought I have choosen forward projection.
I did split the glass in two surfaces so that the decal is only applied to the “outer” surface.
Thanks Joao
I guess the decal texture is two sided so it´s projjecting “forward” from the front and back sides.
Any ideas on how to solve this apart from spliting the glass in a front and back side ?
Thanks
Joao
This looks like a bug in Brazil with decals. I filed it as http://mcneel.myjetbrains.com/youtrack/issue/BR-2071
Hopefully this can get tuned up soon.
Thank you Brian,
On a side note, I am really enjoying experimenting with Brazil, particularly when complemented by Neon.
Regards
Joao
