Decal gets covered by metal material
If I use the metal material as a base, the .png decal gets invisible.
Plastic, paint and plaster material seem to work well. Gem and glass get some strange results, but metal completely covers it.
I’m seeing this in rendered preview but the same thing happens if I try and render the thing.
It also occurs when I use .jpg.
Tnx
Hello - yep, I know… this is because the decal takes on the reflectivity and transparency of the base material. I think there is a bug item for this, but if not I will add one. You can get somewhat better results if you change the metal material type to ‘Custom’ and reduce the reflectivity.
There indeed is a bug item for it - for Raytraced I think the current plan is to keep decals diffuse. There seems to be confusion about how the decals should be interpreted. The original idea is the current way, but I think that based on feedback from users this might be changed to what appears to the general.
I couldn’t find the specific decal on metal/glass/paint/plastic item through the public YouTrack interface, @BrianJ can probably find it easily. The Raytraced item is RH-45742
hmm, what I would do in such a case is to make the logo/label on another surface. I don’t know, just a thought. I don’t use rendering that often but I see labels on bottles as separate objects, so I would model them this way.
@jesterking - there is this: https://mcneel.myjetbrains.com/youtrack/issue/RH-29010
Currently it is not public, I don’t know whether there is a reason for that or whether it’s just an oversight…
We have been working on decals in the Rhino WIP. Here is an example using a metal water bottle with a matte decal:
The feature page is here: Rhino WIP Feature: Material Decals
It also works on the Glass material also:
