Hello, I’m working on a python script, and I want to use a brep as an input and to create a mesh with MeshBrep inside the script. I initialize the parameters with SettingsCustom and when I create the mesh, it returns the error: Data conversion failed from Goo to MeshParameters.
I thank you in advance if you can help me to understand the problem.
meshbreppython.gh (5.7 KB)
Well … P is not my game (meaning that some other good Samaritan must resolve that for you) but given the opportunity … if you do this > that conversion ops I would strongly suggest to add several checks in case that things are not going according to plan.
Open attached (load first R file for the demos) and see the logic (it’s C# but I do hope that the checks are clear).
MeshFromBrep_EntryLevel_V1.gh (118.0 KB)
MeshFromBrep_EntryLevel_V1.3dm (353.4 KB)
For instance see that with the wrong meshingParameter you start with a closed Brep and you end-up with an open mesh:
I would advice against using ghpythonlib
for this and either go through rhinoscriptsyntax
or RhinoCommon directly. The latter like so:
meshbreppython_RhinoCommon.gh (4.3 KB)
You can inspect/get/set further meshing parameters through the properties of the MeshingParameters
class.
Thank you for your answer, I start using RhinoCommun, and it solves also other problem I had. I will learn it more in details.
