Mesh.CreateFromBrep fails
I know similar issues have been reported before.
I use these settings to mesh more than thousand solid Breps that I created before programatically.
Meshing fails on two of them.
two of four Breps fail to mesh in RhinoCommon.3dm (1.6 MB)
open Rhino.Geometry
let meshing =
    let m = MeshingParameters.FastRenderMesh
    m.JaggedSeams <- false
    m.ClosedObjectPostProcess <- true
    m
for guid in rs.ShownObjects() do
    let brep =  rs.CoerceBrep(guid)
    let mesh = new Mesh()
    Mesh.CreateFromBrep(brep,meshing) |> Seq.iter mesh.Append
    print mesh.IsValid
I could narrow the problem down a bit:
I am on Rhino 6.20.19322.20361
Hi @Goswin,
This code seems to produce closed meshes (no naked edges).
import Rhino
import scriptcontext as sc
def test_mesh_breps():
    filter = Rhino.DocObjects.ObjectType.Surface | Rhino.DocObjects.ObjectType.PolysrfFilter
    rc, objrefs = Rhino.Input.RhinoGet.GetMultipleObjects("Select surfaces and polysurfaces to mesh", False, filter)
    if rc != Rhino.Commands.Result.Success:
        return
    tol = sc.doc.ModelAbsoluteTolerance
    mp = Rhino.Geometry.MeshingParameters.Coarse
    mp.JaggedSeams = False
    for objref in objrefs:
        brep = objref.Brep()
        if brep:
            results = Rhino.Geometry.Mesh.CreateFromBrep(brep, mp)
            if results:
                mesh = Rhino.Geometry.Mesh()
                mesh.Append(results)
                mesh.HealNakedEdges(tol * 100.0)
                sc.doc.Objects.AddMesh(mesh)
    sc.doc.Views.Redraw()
test_mesh_breps()
Does this help?
– Dale
thanks for your fast reply @dale, it helped !
