I have a problem with using Rhino Lands Design Plug in.
I am trying to use cut and fill tool but it makes weird holes and bumbs.
How can I fix this?
It might be related with your previous operations you did on the same part of the terrain. Please send us the file to landsdesign@asuni.com
We will explore it.
It looks like you created the terrain using curves that were defined in millimeters. Later you could have changed the document units, scaling the whole terrain object. Is that right? In that case, the Terrain internal input data has too big coordinate values, causing precision issues.
You can solve that following these steps:
We plan to add an option, in future versions, to automatically correct these kind of problems.
Dear Albert,
Thank you so much! Your instructions did fix the problem.
Have a great weekend!
