Custom display mode does not come out in print
I’m having a hard time trying to figure out the issue here. I created a custom display mode with a grainy black background and wanted to print it directly from Rhino. The display mode shows on my layout correctly but when I start to print, it comes out like this.
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Educational, build 2025-09-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.14
Primary display and OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 7-27-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.88
Integrated accelerated graphics device with 1 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 7-27-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.88
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-20-2021 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-27-2025
Driver Version: 32.0.15.8088
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\pollination\plugin\8.0\Pollination\Environmental_Analysis.rhp “Environmental Analysis” 0.0.0.0
C:\Program Files\pollination\plugin\8.0\Pollination\Pollination.RH.rhp “Pollination.RH” 1.54.16.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.257\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.257.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.54.16\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.54.16.0
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.23.25251.13001
Did you use the background to create the dark background or did you use environment like for rendering?
I am 70% sure that, if you create it as an environment and create the custom view as derived from rendered or something, it should work, I did something like this in the past.
Hi Zoilo -
From your images, it’s hard to tell what’s going on. Please always post relevant files such as .3dm model files and .ini custom display mode files.
At any rate, did you check the “Background Color” option under the Visibility heading in the print options?
I’ve changed the visibility options to check background, it did change color, but the background is based on an image I made.
Attaching here the .3dm file and the .ini
GRAIN ZM BLACK.ini (14.4 KB)
Test Print File.3dm (2.8 MB)
