Curves of cylinder won’t display
Hey Everyone,
Im trying to make a front view of my model but Rhino clips the side of the cilinders (see screenshot)
Any clue whats going on?
Graphic drivers are up-to-date
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 (NVidia) Memory: 6GB, Driver date: 11-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.17
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-9-2023
Driver Version: 31.0.15.4617
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\nielshalferkamps\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22353.1023
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
C:\Users\nielshalferkamps\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hi @Niels_Halferkamps
It looks as if maybe you are in wireframe mode, and if that is indeed the case - and you have isocurves turned off, cylinders will show up as just the top/bottom edges and the seam along the vertical axis. If you look at the same geometry in perspective, you’ll see what I mean. If this is technical view mode, there’s most certainly something wrong.
HTH, Jakob
It’s indeed in wireframe mode. But that means we should not be using Wireframe anymore to make 2D drawings. Thank you! (technical mode works properly)
