Hello, long time user, first time caller.
I’m currently running Windows 10 with an NVidia GTX 1070 Ti. Behavior started approximately a week ago, and before that Rhino ran just fine on this computer without issue for years, so I’m not convinced it’s a GPU issue.
Basically, when I open a .3DM file, Rhino looks like this:
I can actually still click things, I just can’t see them, so otherwise the file opens fine.
I’ve tried various things. If I open Rhino directly instead of opening a file, it does the same thing. All the viewports are there, just black.
If I open Rhino in Safe Mode, it does work:
but okay… I’m in safe mode and can’t work exclusively in Wireframe.
Now if I open an .STL file, everything works just fine, regardless of Viewport display property. I can even hack it a bit by opening an .STL file and just importing the entirety of a 3DM file, although this is not a viable long-term solution.
I’ve updated my GPU drivers of course, just in case it is a GPU problem.
“Just uninstall and re-install Rhino dummy.” Yeah, I did that. Still doesn’t display correctly. Which does have me wondering if it’s the GPU somehow but I still don’t buy it. When I re-installed Rhino it clearly saved all my configuration settings, so I suspect there’s something there, but I don’t know what.
Anyone encountered this problem before or have any insight? Is there any data I can provide to aid troubleshooting? Thanks.
