Clipping Plane Issues
I use Rhino 7 daily for work. Beginning earlier this week I have suddenly been seeing issues with my display whenever I attempt to use a clipping plane. This problem applies to any model that contains curves (curves, curved surface edges, etc.) but the more complex the file the worse the problem becomes. My machine is built out with an Intel(R) HD Graphics 4600 and an NVIDIA Quadro P1000. I have gone through every display setting my team and myself can come up with, updated all drivers, updated Rhino and Windows, and finally re-installed Rhino entirely. This is causing considerable delays on all of my projects, if anyone has experienced this issue and found a solution I would be most grateful for your assistance. Thank You.
W/O Clipping Plane:
W/ Clipping Plane:
Hello - can you please run the SystemInfo command in Rhino and copy/paste the results here?
I replied to @gcoleman in tech support.
He is running very old drivers and his monitors are not connected to his good GPU.
He is contacting his IT support to get the right monitor cables.
