I drew a surface and projected (adapted) a curve of grade 5. The curvature graph is performing well.
Then I extend the red edge of the surface with the “smooth” and “merge” option and extend the curve over the entire surface (ExtendCrvOnSrf).
The curvature graph, in the stretch of extended surface does not show a good trend. Quality curvature.3dm (76.2 KB)
How can I improve everything by making the whole curve on the surface continuous (g2)?
(Bug? Rhino command limit, or my lack of capacity?)
I don’t think it’s just a multiknot problem… the graph is always disastrous!
That’s why many users use Alias, Nx or Catia.
If you can do better let me know …
The answer is (as so often) VSR/Autodesk shape modelling had a curve projection tool, that projects curves to surfaces resulting in smooth bezier curves and telling you about the deviation from the surface.
In fact, the tools developed not optimally give this kind of results.
And in these examples that Mcneel must have more attention, providing more quality …
I don’t think it takes millions of dollars or thousands of developers to do this … you need planned action and a willingness to head in this direction …
I wonder:
after the late VSR (now no longer available for Rhino), why doesn’t anyone want to invest by producing a class A modeling tool set to combine with Rhino as a plug-in?
They develop everything from SubD (Clayoo), to BIM (VisualArq), etc.
We would also need a plug-in that can also do better the Fillets, like “NPower” … it would be a dream!
You “XNurbs” developers, for example, who are so good, why don’t you think of a set of commands similar to VSR, in addition to your excellent multiblend?
This tool, like many others, needs improvement. It could be a starting point…
I refer to situations like this when I say that I would like to see improvements in “classic” tools in Rhino and not just SubD, Grasshopper and rendering.
Many attack me, but they should look beyond my words; they should not misrepresent the meaning of my speeches which are for good and not empty criticism…
If a command was born, for example from the time of Rhino 4, it is not said that it must remain the same for many versions … If Rhino wants to become really performing in many fields it should decrease the gap with other Cad, otherwise it will always remain behind …
For the love of god, take down the pathos levels a notch or two…
And don’t worry, we all secretly love you.
This place wouldn’t be the same without you…
Sorry to discover this post too late, yes those curve on surface are always many points and multi-knot with command of extend curve on surface, someone suggested me to use fitcrv, which can clean the curve with less point, but when we trim the surface with that curve, the trimmed edge/ curve on surface is just a different curve than the curve created by fitcrv…
It looks like impossible to reduce points on those curves “attached” on surface….its kind of a constraint.
I will try to avoid using those edge/ curve on surface to create new surface. When I need to join a surface with that edge, I will just matchsrf with Refine enabled.
hm well it seems to work if you use divide with a fairly low amount on a complex curve that was extended, then use CurveThroughPt with option interpolate and the curve sits pretty good, does that help? you can also use pull to be certain it follows the surface but the interpolated curve sits pretty exact in my case already.
