If there is nothing like that, then I would like to ask about adding it in future to Rhino (feature request).
I’ve read that something like that was a feature request some time ago: WISH: blend adjustable curve on surface but I’m not sure if it`s still valid in v8. If not please add it to the list again.
I think it could be helpful to blend curves/edges already on the surface to split/trim.
Maybe it’s not the best example but we may bend this surface and the red curve should follow surface curvature in the first place
I think I know what are you saying but the G1 curve after rebuilding to G2 will meet only G1 accuracy but with CP count of G2. The same should be here. Maybe in your question case some CP will be unused with changing shape (you can raise CP count without changing the shape).
So in other words even if you ask there for G1 curve on G2 surface it will be G2 which looks like G1 but lays on G2 surface.
I can no longer find a video on the net (I think it was by Catia v5) in which you could see the operation of the “blend curves on surface” command. Years ago I posted this also here on discourse … I don’t know how to find it.
once the command has been started and the curves have been chosen, in addition to the blend surface on which the curve should lie, from the drop-down menu it is possible to choose whether to have a continuity in G1 or G2.
No need to project the blend curve …
