Curve cut mark
How to generate marker gaps through points in a closed curve
(}T1}NHM~$KE1EFL31EOQ_2
check out
_OrientOnCrv
for an easy workflow - best work with closed curves, this will allow you to combine the curves with
_curveBoolean
check help for both commands for more / detailed info
kind regards - tom
Hi, this is a closed curve, how to generate a gap by dots on the curve?
i am not fully sure what you are trying to do, but maybe split or trim might help. best you post a sample file and a sample or a sketch of how it should look like.
Curve cut mark.3dm (54.1 KB)
