Hi all, I’m a bit stuck after making good headway as a complete noob to Rhino.
How can I use the curve of a surface as a cutting tool? I’ve used make hole successfully but only when I create poly lines or solid objects from Rhino standard tools.
The surface came from a jpg file, using the vectorise plug-in, and generally the results are great but I need to cut the lettering from the logo and can’t seems to join my surfaces to make it a cutting tool for the solid object. Can anyone think of a way to do this ? I’m starting the 3d printing journey and keen to hone my skills asap…
I’ve looked for tutorials but so far none have the answer ! Time to join the forum!
I will upload the file if anyone has time or the patience to take a look? Thanks, Stu
DATA Hoax logo makehole.3dm (1.3 MB)
