I noticed that Ctrl+Tab is no longer working in the last WIP to switch between viewports, this is annoying since I use that all the time.
@dale @Gijs Had this ever been resolved? I am running into a similar problem with Version 8 SR3
(8.3.24009.15001, 2024-01-09).
If you use CTRL+(SHIFT+)TAB in the seconds after a command, Rh8 will switch two viewports at once:
(^sadly the embedded browser video player has a black gradient at the bottom, hiding the important bit. Please download and then view the clip)
Iâve used the gumball here, but it happens on all other commands I use too.
Can you reproduce this?
It feels related to the new sluggishness and milliseconds of short freezes Rh8 has.
hi @DuncanW I see that here, though itâs not time related, I tried a couple of different commands, like a Box, FilletEdge, Rectangle. Whatâs odd is that the first two have this issue, but Rectangle doesnât. I also noticed that rotating or moving the view after the command will âfixâ this.
RH-80199 Switching viewport with Ctrl+(Shift)+Tab hickup
Many thanks. And yes youâre right that moving the viewport (ie giving it focus) âfixesâ it.
Do you also get the mini freezes or is that unrelated?
No, I donât see that, can you post a new thread and provide the right info? Thanks
