Select all and immediately try to pan/rotate the viewport
The viewport is stuck until the pre-selection in the block manager has kicked in. Also deselecting objects, and the block manager needing to update, causes the same issue. The more blocks there are, the more pronounced the issue is.
This had not been present in Rh7. I presume as it did not have the semi-selection state of blocks.
Can you make the semi-select state of Rhino8 blocks optional? I’m afraid it does nothing for me.
Although your drivers are recent I have seen that updating to drivers from this year gives better stability, so worth a try. But again, not related to your issue. Just thought I’d mention it.
I’m not sure if @lars made performance changes since Rhino 8.3 to the block definitions panel, but he’d be the one to investigate this more if it still happens in 8.4 (current service release candidate) or 8.5 (internal version, soon to be service release candidate).
