Ctrl + Shift + RMB doesn't work
Hi everyone,
I’m having a strange problem with Rhino on my new computer.
I cannot rotate the viewport using Ctrl + Shift + RMB drag. However, the other mouse and keyboard controls work normally.
Here is what I have checked so far:
  • Ctrl and Shift keys work normally.
  • Right mouse button works normally.
  • Other Rhino mouse controls work normally.
  • I checked the settings under Options → Mouse, and they appear to be correct.
  • I also tried using a different mouse, but the problem remains.
  • The same Ctrl + Shift + RMB operation works normally on my old computer.
  • The problem occurs on the new computer, even when using a new/empty Rhino file.
So it seems to be specifically the Ctrl + Shift + RMB combination that is not being recognized for viewport navigation.
Is there any other Rhino setting, Windows setting, or background software that could block this specific mouse + keyboard combination?
Any suggestions would be greatly appreciated. Thank you!
Hi Ziyun -
The option that controls that behavior is on the Rhino Options -> View page: Pan plan parallel views with Control+Shift+RMB. You’ll need to turn that off.
