On Windows, the command window keeps a log of all the data entered to create the macro; on MacOS I can’t find that log. Is it somewhere hidden? Or…?
Hello- use CommandHistory for tthat on both platforms.
oh, I see. Thanks.
Question then. I have an export command with a lot of options. Is there any way to record that for a script other than just write it down or take screenshots?
You can copy/paste from the command history. You will still need to edit the text somewhat after.
The options entered into the export dialog box do not show in the command history, unfortunately.
Hmm, that may be a Mac thing…?
This is Windows Rhino command history (F2) after running an .stl export:
You can also copy/paste from the command line while the command is in progress. But since Mac Rhino doesn’t have a command line… (V8 will hopefully be better)
Do you have the following in Mac Rhino?
