Hi
I am trying to make Solid works CAD file porous using Rhino Grasshopper. Is it possible to create a custom CAD file porous by importing it to Grasshopper or importing it into Rhino? I am a beginner at Rhino
Hi @vikashkumar0603,
you can import models into rhino and reference them to grasshopper.
I think you should provide some sketch or reference of what you want to achieve so someone may give you some hints.
Also it is always a good idea to search the forum previously.
And also sharing the file will increment the possibility to help you
dec11a.SLDPRT (56.8 KB)
Hi McNeel
Thanks for your quick and informative response. I could import the CAD model into Rhino, but My main goal was to make it uniformly porous, as I mentioned in the attachment. Consider this as a unit cell, which needs to be spread overall CAD Geometry. Kindly tell me the procedure or suggest any video for the step procedure.
