I need help with import file from Rhino 6 Grasshopper to SolidWorks 2018. I tried to save file as Model 3D Rhino 3*.3dm and *.igs. When I import *.3dm file receives a message that the object has no planes / solids. When I import *.igs file there is no message but nothing is in this file. I have created 3d print cellular like in photo using Grasshopper. Can anybody help me? How do it correctly? Finally I want to use Simulation in SolidWorks.
rhinosceros|690x313
Best Regards, Kacper!
Not sure if this will help, but I think you need to bake your geometry to Rhino, and then you will be able to export to IGES/Parasolid/STEP, all of which are importable to Solidworks⌠I will recommend using Parasolid as it is the native modeling kernel for Solidworks (I think).
Thank you. Works.
Hi againâŚ
I have one more problem with my model from Rhinoceros. I want to put in my structure to SolidWorks Simulation. My model must be a âsolid modelâ, not a surface. I tried to change surfaces in solid in SolidWorks and in Rhinoceros but it donât work. In SolidWorks i can only make a rod empty inside. Anybody have an idea? Maybe there is an option in Rhinoceros that i donât know yet? I upload a ScreenShot of my model in Rhinoceros.
Thank you for help.
Maybe uploading your model would help?
When you import in Solidworks, is it open or a closed surface? If, it is a close surface you can âknit surfacesâ in SW and convert it to solid. If it is open you will have to work on your topology to achieve a closed brep either in Rhino or SW.
If you are using Pipe, as in your first post, you can right-click on the âEâ (Caps) input and use âFlatâ or âRoundâ instead of the default âNoneâ. This will produce âClosed Brepsâ (solids) instead of âUntrimmed Surfaceâ.
Imported model in SolidWorks has a open surface. I donât have to work with my topology, because advice from Joseph_Oster work!
I upload a photo how it look like now in SW.
Thank you guys very much again!
And how before
The âRoundâ ends instead of âFlatâ on Pipe might work even better in this case? In GH, however, they would likely cause Solid Union to fail.
Hi
After importing the geometry in solidworks, multiple parts are created like lines, points, surfaces. It has caused Solid Union to fail. Do you know any way to unite all the different parts?
