I’m having a real headache with creating GH Style VA Objects.
I want to create a simple Countertop with Depth, Width, Thickness Parameters.
I want to be able to get the area of that countertop (WidthxDepth). I’ve created a custom param FRN_Area, I’ve put it in a Table. I’ve even created a script which should take W and D values, multiply them and change FRN_Area parameter values. But nothing works, the output dos not change.
@suMArch Try to connect the calculated area in your Grasshopper definition to a “Number” component (instead of creating a custom parameter for that, which won’t update dynamically with the object)
