Dear all,
Any idea on how I could create the flat bottom lid (first layer) on the following design ?
I would like it to be a spiral (image below).The aim is to 3D print it.
Thank you in advance,
Tim
test_plate_2.gh (16.9 KB)
Dear all,
Tim
Here’s how I’d do it for regular 3D printing.
If you are doing clay printing and want to show the spiral shape this method won’t work. In that case you need a way make a single spiral curve that has the shape of the bowl (vertical radius controlled by the GraphMapper output) rather than a straight-line increase that results in a cone shape.
test_plate_2-bb1.gh (31.7 KB)
Hello @Birk_Binnard
It looks very good. However, it is not a single path anymore and I’d like to export the gcode directly from grasshopper. How can I do ?
Thank you !
Grasshopper doesn’t do that. Bake the GH geometry and then export it from Rhino as an STL file. Then you need to use a slicer program to input the STL file and output the GCode required to print it. PrusaSlicer is a good one to start with. There is a more fancy version called SuperSlicer that I use, but it has so many variables it will probably scare you.
Hey Leblond,
I looked at what you wanted to do, I also print directly from within grasshopper by XYZ values and constructing my own G_code so it surely is possible. I looked at your grasshopper file and did some what the same for the top section of the bowl as you already did. Was this what you were looking for?
test_plate_3.gh (17.7 KB)
Wow ! It is exactly what I wanted!!! Thank you so much @Martijn.w
No problem
