Creating Blocks Using Human in GH
Hi all,
i hoping this is a simple fix for someone.
I am creating a script to process Trees from a survey file.
Essentially I want to extract the points and diameter (radius) of the tree canopy and re-build a block with an attribute such that I can export that as a Shape File.
I have worked through a process of extracting the data i need to re-build the block but I am struggling to get a method where i can pass a new circle as geometry for each block. I have attached the script. If someone could provide a bit of direction that would be appreciated.
Trees_01.gh (17.3 KB)
