Hi everybody,
I’m trying to create an organic (if possible even growing) mycelium fiber structure in Grasshopper. This fiber structure is placed in a sphere with a diameter of 27 meters.
What is the best way to create a structure like this? While researching I tried various options, my professor told me to use Voronoi which does work but the result is still quite far from the desired outcome (see attached references), what could i do to achieve the most accurate results?
I was also wondering if using a Python script could be the right direction, even though I’m not quite familiar with that yet.
If someone of you has any idea or even did something like that before I would really appreciate your help and input!
Thank you!
Here are some of my references
