I am trying to create several regions. As inputs, I am using the Data Tree of Revit views and the Data tree of the closed boundary. When I place multiple views as Data Tree, not all regions are created.
I was expecting that component will make in your example a total of six regions. 3 for view 1, 2 for view 2, and one for view on branch three. Is this possible? The same way as other components work. If one branch has one Revit view and severe boundaries then that Revit view is matched with each boundary
if you create a region in the Revit UI, placing several Rectangles its going to create one region. You would need to match the list length to the views and graft individually if you want individual regions.
