Create a proper technical drawing from a 3d model
Hi 177 -
Have you done any work in Rhino?
The 3D model is intact. The clipping plane is something that you can turn on or off per viewport / detail. If you absolutely want to, you can use the TestDetailSection command to create a clipping plane and detail in one go on the layout:
