I need a line that intersects 2 curves and have a specific length (This need to be on vertical position)
Any idea?
Thanks a Lot
Any idea?
Thanks a Lot
I think in this case you might simply Offset the upper line down(well more generally along the direction you want the length to be) by 5 units to get an intersection point you can snap to when drawing the line.
Hi Jesus,
try this:
EDIT: 2 should be 5 in your example
Or copy both to their respective side and find the intersections like so:
HTH
-Willem
One way to do this is shown in the enclosed file. First draw a vertical 5mm line starting anywhere on the red line. Then copy the red line from point A to B. Then copy or move the vertical line from point B to C.
5mmVert.3dm(27.5 KB)
simple and effective. Thanks you so much
Nice example. Thanks you
nice explanation. Thank you so much
