Create a Bump Map From 3D Objects?
Hey there,
I want to create bump maps to use as textures for printing with my UV printer.
I’m pretty new to Rhino. Is it possible to convert 3D objects into greyscale bump maps?
Thanks!
With Rhino 7 enable the distance channel in the render channels setting in the rendering panel if you are not on automatic. Then render and inspect the distance channel
Render from top view if you need a constant floor
Perfect. Now that I know about the distance channel I can learn more about it.
Thanks Nathan!
