Rhino Render Distance Channel Error?
Would it be possible for someone to clarify if the Distance Channel is working for Rhino 8 Render? The exported image is certainly not a distance map/zdepth - but I may have a setting which is distorting the image.
I’m using the Distance Channel for a controlnet for Stable Diffusion (ComfyUI). It’s part of a series of controlnets which influence the formation of an AI latent diffusion image and need to be perfectly aligned - defined by the Camera View. Ie exporting the viewport ShowZBuffer isn’t an efficient solution.
The export for the depth controlnet needs to be controllable by resolution, camera view, image ratios… just like a typical render - with a Distance Channel.
Perhaps someone has used a Depth Channel plugin export?
Any clarification/help would be great!
What do you mean it is not a depth map? Make sure you save the depth channel as EXR.
Also note that depth map as shown in the render window is a visualization, the data is in floats from 0 (where camera is) to a very high value (where the background is hit). Other than that the value in the pixels is the distance in model units from camera to that point.
The depth channel shown here:
Saves as EXR gives this file: depth_for_box_and_sphere.exr (222.5 KB)
It’ll look pretty white, since all values are over 1.0. Plugging it into a compositor to map values to some range that is easier to visualize:
Sampling a point that is not hitting any geometry gives very large values:
In the compositor shot above you can see I used the value 100 000 to use as cutoff.
Hi Nathan,
Thanks for the reply. I’ve rendered a simple scene in Rhino 8 to show the issue more clearly:
RGB Preview:
Distance Channel Preview
This is what I would have expected in the Distance Preview (different angle), rendered in Rhino 7 with the same settings:
I tried saving the Rhino 8 distance map as an EXR format and have adjusted the exposure settings in Photoshop 2025 but the depth information is not there. All other saved formats: jpg, png etc seem incorrect, as per the preview too.
Photoshop - with adjusted exposure to show variation in image:
The depth information is not working?
Here’s my Rhino Model:
001.3dm (92.5 KB)
Gijs de ZwartGijsMcNeel
Aug 6
Thanks for reporting,
I added RH-83223 Show Distance Channel broken
As @cdordoni points to depth channel is fixed in Rhino 8.13, which should become the service release in a couple of days.
This is the depth channel saved from your 3dm:
BGT_77_001_depthchannel.exr (360.6 KB)
Depth values range from ~19000 to ~30000
Note that although a depth channel is typically a single-channel image we currently save it as RGBA with the RGB channels each the same value (being the depth value).
Thanks for the update Nathan. I tried to search for some info on the Depth Channel before posting, but I couldn’t find anything relevant on this forum. Perhaps I was looking in the wrong location?
It would be great to have ‘save paths’/ ‘file type’ for each channel, rather than have to do it manually each time from the render window? Perhaps there is a way that I’m missing - but it doesn’t seem obvious to me.
I look forward to updating Rhino with the Distance Channel resolved - as the Distance Map together with Normal Maps work really well with Controlnets for Stable Diffusion and AI ‘rendering’.
There is this open issue: RH-52758 Allow render engines to save arbitary many channels to one file from Render Window
I’ve added this thread to it.
Thanks Nathan,
The issue isn’t about saving the channels into a single file - a more efficient solution would be to set paths for each type of render output - ie depth map is saved here as x format… RGB is saved here as y format… etc.
Also - wouldn’t it be great to be able to save multiple render settings for each view - instead of only having a single render setting per saved view?
With more people using AI workflows it would be great to have more integration with the Rhino Render output.
Logged as RH-84701 Preselect file format based on visible channel
I don’t know what this means. What multiple render settings do you want to save, and to what?
Perhaps I have misunderstood the way render settings work but within the settings dialogue box there is no way to save the Render Settings as an option. It seems to be a global setting and therefore there is no way to save presents. This would be useful to change to specific resolutions, quality settings, maintain continuity between files etc. The view: display mode settings are also based on these global settings.
Even when I try to define for a particular view - it doesn’t save the render settings as a present?
Perhaps I’m missing something fundamental ?
Render settings are document settings. They are separate from view settings.
Absolutely agree. I’m suggesting having Render Presets within the Document/File - to enable switching to different render settings, and to import/export these settings to another file. Similar to how most other Render programs are set up.
Render presets is tracked in RH-74619 rendering preset - save user defined custom preset . I’ve added this thread to also that issue.
