Go to: Options > View > Display Modes > Shaded > Shading settings > Color & material usage > Custom material > Customize…
When I hit the Customize… button, the Custom Object Attributes Settings dialog box opens but immediately an error box opens on top of that:
Rhino.exe - System Error
A new guard page for the stack cannot be created.
First time I’ve heard or seen anything like this… Not even sure what the error is indicating…might be a new Eto thing for the UI…but I have no idea. @stevebaer and/or @JohnM might have better info.
I don’t believe any of that UI has been converted to Eto. When I bring up the customize dialog it looks like an RDK dialog. @johnc is this a dialog that you work on ?
@stevebaer Which dialog? The customization dialog, or the error dialog that Wim is reporting? I wrote the customize dialog over a decade ago…and it hasn’t changed since. I guess the first thing to get answered is what and where is the dialog that Wim is seeing coming from and why?
Render version: 3.3
Shading Language: 3.30
Driver Date: 11-16-2012
Driver Version: 8.970.100.7000
Maximum Texture size: 8192 x 8192
Z-Buffer depth: 24 bits
Maximum Viewport size: 8192 x 8192
Total Video Memory: 1 GB
Thanks; this may be the problem. We are experiencing some problems with the ATI drivers and are frantically (yes frantically) working to fix this. Does the WIP work at all when you go into rendered display mode?
Nope!
Well - I can get it to sort of work, but anything that doesn’t have a material assigned to it just displays a sort of silhouette blob…not uninteresting, but not really what one expects if you understand…
