Cplane to match clipping plane
Hi All, is there a straight forward way to place a Cplane in the same orientation as a clipping plane? That way you could draw on your clipping plane.β€”-Mark
Thanks John
You need to break down your problem into smaller steps and solve them individually.
First thing it is to find a way to import the desired clipping plane into Grasshopper and I found a solution here.
Hello- CPlane > Object should do it.
I set up a macro to set the CPlane to the gumball.
I often set the gumball to an object and I might then rotate it 90Β° around an axis and then set the CPlane to the gumball with the macro.
Thanks everyone for the direction.β€”-Mark
@martinsiegrist Can u share the Macro for CplaneToGumball?
It’s a button with nothing more than this:
Ah, duh me - didnt realize that option under Cplane :grinning: Thx
