I have been playing with RiR for the past few weeks and have loved it so far. I was wondering if there is a way to turn a sheet element into curves or any other way of exporting sheets from Revit and importing them into Rhino automatically (non-raster).
In Revit this is done via Export to DWG, Rhino can import the linework from that format using Rhino 8 import component.
export the sheets manually to dwg file inside revit, then import them into rhino
Is that what you’re referring to?
Correct. Revit does its version of ‘Make2D’ during the export process.
great thanks alot
