When using CopyToLayer and selecting the “+” in Layer To Copy Objects dialog window, it would be nice to be able to rename the new layer within that dialog, rather than having to use the Layers Panel. A small time saver.
That makes sense. I never used that dialogue box, I always used the Layers panel and the new layer is highlighted so you can rename it automatically. The issue in the Layers Panel, is you cannot copy or move an object at the same time like in the Menu dialogue box.
«Randy
I see what you mean. Logged in MR-2908. Seems like a paper-cut to me.
The Paper Cut:
RH-36511 CopyToLayer dialog: plus button should create layer and allow renaming
is finally fixed in Rhino 8.
