Is there a way to convert mesh objects to Nurbs objects?
I import objects from 3Dwarehouse, (SKP format), It is inserted as mesh,
and I want to convert it to Nurbs…
Thanks
Rachel
Thanks
Rachel
When you import an SKP, you get the option of ‘Trimmed Planes’ or Mesh. If you choose ‘Trimmed Planes’, you’ll get polysurfaces / Nurbs objects.
Thank you very much !!
and in general - is it possible to convert mesh object to nurbs object?
There is the command _MeshtoNURB which converts each mesh face to a nurbs surface.
Not “automagically”.
The process is called Reverse Engineering. It’s a painful, slow slog that uses the faceted mesh as reference geometry to remodel it using NURBS curves and surfaces.
Here’s a warning FAQ about what MeshToNURBS is intended for:
http://wiki.mcneel.com/rhino/meshtonurb
