I am trying to create a template in Rhino that allows me to import a DWG created in another software, and applies overrides to properties such as font, text height and block scale. Is it possible to do this by perhaps setting up layers with predefined properties that will override those from the original DWG.
For example;
I import the DWG which has a layer called “LABEL_TREES” containing text. Upon import, all of the text is way too big and the wrong font.
The template that I imported the data into also has a predefined layer called “LABEL_TREES”, so perhaps this layer could have information stored within it somehow to tell the text what size and font it should be? Or are there global values somewhere that I can modify? Or would this require some kind of scripting or macros?
Essentially, I am trying to automate the conversion process as much as possible, since there can be literally hundreds of layers that need similar modifications.
Thanks in advance.
