I’m new to sub D modelling and can’t figure out why this Hand did not convert to sub D surfaces.
I created 1 four sided sub D surface and expanded from there.
Thanks
Sub D Hand.3dm (8.5 MB)
Thanks
Remove crase - command.
Yes true.
I’m trying to figure out why all the edges didn’t change at the same time.
i don’t know how to answer that
Here is the issue. When I do a gumball extrude and then reflect and then select and hit the tab key only part of the piece softens up to a sub D surfaces. Please give it a shot and let me know if the same thing happens with you.
Cheers
Sub D Hand.3dm (50.1 KB)
I’m not certain how to remove a fold.
Thanks
Sorry i missed the detail on your image.
There was something weird going on with your file. I played around with it a little to create a decent base mesh for a hand model. Ended up deleting some faces and re-extruding. You can play with it as you see fit.
