I have a set of gis data (citygml files of houses…), the files are names *.gml
Does someone know a way of converting this stuff to a usable cad format like 3ds, dwg, obj. or anything else rhino is able to process?
thanks
Andreas
thanks
Andreas
OK, I found something really nice and free:
http://iai-typo3.iai.fzk.de/www-extern/index.php?id=1931
worked very well in my case
Andreas
I’m experiencing the same problem here but your link doesn’t work anymore. what was it exactly?
Thanks.
Hello - dunno if this helps - https://www.citygml.org/software/
Hi Walter. How did you end up getting gml data into rhino i wonder? Thanks in advance, Anika
Hello;
I was wondering if anyone knows how’s the process act in reverse? Like, how to convert a Rhino file into CityGML format?
Thank you for the reply! Do you know if there is a student license available for Rhinocity? And should I have Rhinoterrian as well?
I’m afraid I can’t help you with any of these inquiries…
Just found Rhinocity after a lot of googling – They seem to be really bad at SEO
Yeah… Thanks a lot anyways
How did you manage to make this work? Can’t get it to work…
Any news here?
Hi there,
try this: https://www.iai.kit.edu/1302.php
(FZK VIEWER)
load your file, export to stl, import to rhino, mesh2nurb, that’s it…
best
oliver
Hi there,
this webservice is also an option: https://3dcityloader.com/city/cologne
For some cities that publish CityGML data, you can download it in various formats (also as .obj)
best regards,
Chris
UPDATE: There also some other regions available now.
Netherlands: https://3dcityloader.com/city/netherlands
Switzerland: https://3dcityloader.com/city/switzerland
NRW, Germany: https://3dcityloader.com/city/nrw
Niedersachsen, Germany: https://3dcityloader.com/city/niedersachsen
Berlin, Germany: https://3dcityloader.com/city/berlin
And worldwide coverage, based on OpenStreetMap, is available here : https://3dcityloader.com/city/worldwide
May be of help for Rhino to CityGML conversion without RhinoCity - From Urban Design to Energy Simulation – a Data Conversion Process Bridging the Gap Between Two Domains - REAL CORP Repository
reverse scenario also possible CityGML → COLLADA → Import to Rhino
