Importing a GML file into Rhino. I would like to import a LOD file of the city of Heilbronn (3D buildings) into Rhino. The file format is GML.
Unfortunately, I cannot upload the GML file here because the format is not supported.
Try Zipping it, I’m fairly certain I have uploaded Zip files before.
Hi @A_H_2
Depending on what version of GML those are, here’s a link to a small piece of software that will open GML files and save them as eg. stl, that can then be imported to Rhino:
HTH, Jakob
Yes, but that Software is no longer being updated and only works in Windows. If you look at the screenshot, Amelie is clearly using a Mac.
I had the same issue so I built a converter, it just spits out STL but it works great!
