I am working with a city model exported from CityGML (exported as .dwg).
When I import it into Rhinoceros 3D, the buildings are organized into multiple layers (e.g. Building, RoofSurface, WallSurface, GroundSurface, etc.).
Goal
I want to create a clean, closed solid in order to extract a 200 × 200 mm section and prepare it for SLA 3D printing.
Problem
The buildings are not clean, closed polysurfaces, but instead consist of many separate surfaces.
There are numerous naked edges and small geometric inconsistencies.
As a result, the following does not work reliably:
Boolean operations
Cutting out a solid volume (e.g. a cube)
Preparing the model for 3D printing
What I have tried so far
I have already attempted the following steps:
MergeAllCoplanarFaces
→ to simplify adjacent planar surfaces
Join / general repair attempts
→ to create closed polysurfaces
Repair Mesh
→ to fix geometry issues
ShrinkWrap (at the end)
→ to generate a closed volume
Result
The model remains messy and fragmented
Many naked edges persist
Boolean operations are unreliable or fail
The model is not suitable for SLA printing
Question
Is there a better workflow for CityGML → Rhino?
Should I convert to mesh earlier in the process?
Is there a robust way to unify/clean this type of geometry?
Thank you for the reply!
Indeed the workflow works more or less good. I will have several files like these to do.
Waiting right now for the printing result. Lets see if the mesh is fine enough for a good smooth print.
The aim is to do a translucent SLA print with a certain thickness.
I am still preparing a detailed city DWG in Rhino 8 for SLA printing. The full model consists of 25 puzzle-like tiles, scaled to 1:1250. The print supplier only needs the outer A-surface as STL; they will add wall thickness themselves.
My current workflow is:
Scale the model to 1:1250.
Move the full assembly close to 0,0,0 while preserving the relative position of all 25 tiles.
Run ShrinkWrap.
Use SplitDisjointMesh and delete the small floating artifacts.
I get a completely clean result:
valid, closed mesh, 0 naked edges, 0 non-manifold edges, 0 self-intersections, 0 reversed faces
about 46.4 million faces per tile
The problem is file complexity.
I tested several ways of reducing it:
Method
Faces
Self-intersections
ShrinkWrap 0.15 / Opt 0%
46.4 M
0
ShrinkWrap 0.15 / Opt 1%
10.4 M
124
ShrinkWrap 0.15 / Opt 10%
8.4 M
122
ShrinkWrap 0.15 / Opt 25%
7.5 M
130
ShrinkWrap 0.15 / Opt 50%
6.6 M
169
ReduceMesh ~50%
31.9 M
195
ReduceMesh Planar Only
13.8 M
1,954
MeshSelfIntersect showed that the intersections in the optimized versions are spread throughout the model, not concentrated around a few bad objects.
I also tested Target Edge Length = 0.20 mm, but that loses too much architectural detail.
My questions
Has anyone experienced ShrinkWrap Polygon Optimization introducing self-intersections even at very low values such as 1%?
Is there a better method for simplifying a clean, very dense architectural mesh without creating self-intersections?
Would you simply keep the clean 46M-face mesh if the downstream software can handle it?
Since I only need the A-surface, would removing the flat underside before STL export be the best next step for reducing the file?
Are there Rhino plug-ins or external mesh tools that work better than ReduceMesh for this kind of dense city geometry?
I wonder if moving the the object to the origin first, then scaling might be a better method to reduce error.
You might try Balancer nPro. for the decimation. It does a fantastic job of reducing the # of triangles and preserving small details due to a tolerance setting that allows a unit value to be entered. You’ll probably need to check to be sure the object is still error free after the reduction.
