CityGML (CityJason) 3d in Grasshopper
json.rar (347.7 KB)
Dear Friends,
I have a CityGML file and Im trying to impro the geometry in grasshopper, then I want to separate buildings to create IDF file from each building using Ladybug tools. But I cannot import the geometry to create the simple 3d of the buildings. Is there anyone who could help me. I have attached the files.
Hi Hassan -
See this post:
Three options:
  1. Search for “FZK-Viewer” (By KIT-University), import the citygml, export as STL, import STL to rhino
  2. Use AntFarm
  3. Import by grasshopper. There is no public available importer anywhere. I´ve searched something like this for months. So I wrote my own one. It´s certainly not that easy. You should go for option 1/2.
Regards,
Paul.
Dear Wim. Thanks for your suggestions. I tried Antfarm, but after importing my file it shows nothing while it says that successfully reads it. maybe you could try it and let me know.
empa_campus_swissbuildings3D.zip (367.4 KB)
Dear Paul,
Actually I have tried both of them but importing file without using semantic information has not been uet possible for me through the above two methods. if you got time I would appreciate if you take a look at it
“it shows nothing”
…did you press “zoom extends”? Or “select all” and then “Zoom selected”. The imported geoemtry should be georeferenced. Therefore many kilometers away from rhino-origin. You have to move your perspective to the imported geometry. If your file is a CityGML file it has to work. I did it 500+ times.
What semantic information do you need?
Using FZK-Viewer, exporting stl:
Dear Paul, Have you developed a way for import GML files? can we be in touch?
hassan.bazazzadeh@empa.ch
