Convert circle to octagon
Is there a way to control the number of sides a polygon will have when using the Convert command? I’d like to convert different diameter circles to octagons. It seems the only way to control is through MinLength, which is restrictive when you have varying diameters.
Thanks,
Dan
Hello - Rebuild to degree 1, 8 points.
Thank you Pascal!
Dan
